  2. How To
  3. How to get more accurate running data on smartwatch?
2025-01-06 1044 15
To get more accurate running data on a smartwatch.
Welcome to Blackview blog.
running data
To obtain more accurate running data on your smartwatch, make sure to input your height and weight. This will help provide more precise information, such as calories burned and distance covered. This is because your smartwatch uses this information to calculate your stride length and other factors that affect your running performance. If you don't set your height and weight, your smartwatch will use default values that may not be accurate for you, which could lead to inaccurate running data. Additionally, your weight is used to estimate calories burned.
To set your height and weight on your smartwatch, you will need to open the smartwatch's settings menu (One example is Blackview smartwatch). The specific steps for this may vary based on your smartwatch's make and model, but they should generally follow a similar pattern:
  • Open the smartwatch's settings menu.
  • Scroll down and select the "Profile" or "Personal Info" option.
  • Tap on the "Height" and "Weight" fields and enter your correct measurements.
  • Tap on "Save" to save your changes.
Once you have set your height and weight, your smartwatch will be able to provide more accurate running data such as calories and kilometers.
Here are some additional tips for setting your height and weight on your smartwatch:
  • Make sure you enter your correct measurements. If you enter incorrect measurements, your smartwatch will not be able to provide accurate running data.
  • Update your smartwatch's software regularly. Software updates often include bug fixes and performance improvements that can improve the accuracy of your smartwatch's running data.
  • If you are still having trouble getting accurate running data from your smartwatch, contact the manufacturer of your smartwatch for support.
Related Product:
#cheap running watches, #best smartwatch for swimming, #best smartwatch for hiking, #best outdoor smartwatch, #cheap smart watch, #Bluetooth calling smartwatch, #The latest smart watches for women, #$49 smartwatch for seniors, #womens hybrid smartwatch
Read also,
Here are some other tips for getting more accurate running data from your smartwatch:
  • Make sure your smartwatch is properly calibrated. This can usually be done by running outdoors for at least 20 minutes.
  • Wear your smartwatch snugly but not too tightly.
  • Avoid wearing your smartwatch while swimming or bathing.
  • Keep your smartwatch clean and free of dirt and debris.
15
Prev article: How to unlock FM radio on your device?
Next article: How to use Google Assistant on Android (Samsung, Blackview, Galaxy watch 4)?
