  2. How To
  3. How to unlock FM radio on your device?
2023-05-10 10593 75
FM radio on Smartphone
As FM radio can be used to listen to music and news without requiring an internet connection, it plays an active role in some countries such as India. According to Indian media 91mobiles, the Indian government requires all smartphones in the Indian market to be equipped with FM radios and cannot be disabled. In fact, most smartphones have an FM radio receiver built in, but it is often disabled by the manufacturer (Blackview phones are one of the exceptions). In this guide, let's explore the ways to unlock the FM radio on Android smartphone/iPhone.
There are a few ways to unlock FM radio on your smartphone. Here are two of the most common methods:
Use a third-party app
There are a number of third-party apps that can unlock FM radio on your smartphone. One popular option is NextRadio. NextRadio is a free app that allows you to listen to live FM radio stations without using any data. To use NextRadio, simply download the app from the Google Play Store or the Apple App Store. Once the app is installed, open it and plug in a pair of wired headphones. The wire in the headphones will act as an antenna. NextRadio will then scan for available radio stations. You can select a station to listen to and start enjoying your favorite radio shows.
Root your phone
Rooting your phone is a more advanced method of unlocking FM radio. Rooting gives you full administrative access to your phone, which allows you to make changes that are not normally possible. To root your phone, you will need to download a rooting app and follow the instructions. Once your phone is rooted, you can install an app called an FM tuner. An FM tuner will allow you to listen to live FM radio stations without using any data.
It is important to note that rooting your phone can void your warranty. If you are not comfortable rooting your phone, you can use a third-party app to unlock FM radio.
Read also,
75
Prev article: How to turn off NFC on your device?
Next article: How to get more accurate running data on smartwatch?
