  2. How To
  3. What cause poor mobile phone reception in house and how to fix?
2024-06-24 1139 1
Welcome to Blackview (Well-known brand of military grade cell phone) blog. Hope the guide helps.
Ever feel like you're living in a dead zone? Dropped calls, slow data speeds, and unreliable connections can be frustrating, especially when you're indoors. But fear not! Several factors can contribute to weak cell signal at home, and there are solutions to improve your reception.
Bad signal in house
Understanding the Culprits: Why Your Reception Stinks
  • Building Materials: The materials your house is built with can significantly impact signal strength. Brick, concrete, and metal all weaken cellular signals.
  • Distance from Cell Towers: The farther you are from a cell tower, the weaker the signal you'll receive.
  • Geography: Hilly or mountainous terrain can obstruct cellular signals.
  • Weather: Heavy rain, snow, and extreme temperatures can sometimes weaken signal strength.
  • Indoor Layout: Large buildings with multiple floors, thick walls, and metallic roofs can disrupt the signal as it tries to penetrate insid
  • Cell Phone Carrier Infrastructure: In some areas, the cell phone network may be overloaded due to high user density or limited network capacity, leading to poor reception in your home.
Solutions to Strengthen Your Signal
While you can't control factors like distance to towers or weather, there are steps you can take to improve your reception indoors:
  • Identify the Weak Spots: Make calls around your house to pinpoint areas with the weakest reception. This will help you target your troubleshooting efforts.
  • Move Around: Sometimes, a simple change in position can be enough. Try moving closer to a window or an exterior wall to see if the signal improves. Sitting by a window on the side of the house facing the cell tower might also help.
  • Check for Case Interference: Some phone cases, especially metal ones, can weaken the signal. Try taking your phone out of the case and see if the reception improves. Generally, rugged phones do not need a phone case.
  • Consider a Cell Signal Booster: These devices amplify weak cellular signals for your home. They are regulated by the FCC (Federal Communications Commission) and require proper installation for effectiveness.
  • Utilize Wi-Fi Calling: If your carrier supports Wi-Fi calling, you can make and receive calls over a Wi-Fi network, bypassing the cellular signal altogether.
  • Invest in a Femtocell: A femtocell is a micro-cell tower for your home, but availability depends on your carrier and may come with additional charges.
  • Upgrade to a Cellular Repeater: A cellular repeater is a more powerful version of a signal booster, designed to cover larger areas or multi-story homes. These devices can be particularly helpful in areas with significant signal interference or large distances from the nearest cell tower.
Read also,
Additional Tips:
  • Contact Your Carrier: They may be aware of network issues in your area and offer solutions.
  • Try a Different Carrier: If signal strength is consistently poor with your current provider, consider switching to a carrier with better coverage in your area.
Remember: There's no one-size-fits-all solution. Experiment with these tips and see what works best for your situation. With a little troubleshooting, you can improve your cell phone reception and say goodbye to frustrating dropped calls and slow data speeds.
Prev article: How to share location between iPhone and Android (indefinitely)?
Next article: How to check available RAM on your phone?
