  2. Smart Life
  3. How to make calls on a smartwatch without phone?
2025-01-18 2170 190
Smartwatches have evolved to become powerful devices that allow users to perform a wide variety of tasks without needing their smartphone nearby. One of the most convenient features is the ability to make and receive calls directly from the smartwatch. Here's a guide on how to make calls on a smartwatch without the need for a phone.
Make calls on smartwatch
1. Choose the Right Smartwatch
Not all smartwatches are equipped to handle calls without being paired with a phone. To make calls independently, you'll need a smartwatch that has built-in cellular connectivity (such as LTE or 4G). Some popular models include:
  • Apple Watch Series 3 or later with cellular support
  • Blackview Z20 Kids Phone Watch
  • Samsung Galaxy Watch 4 and later models
  • Fitbit Sense with built-in connectivity
  • Blackview Z10 Kids Phone Watch
  • Garmin Venu 2 Plus with LTE features
These smartwatches allow you to make calls directly from the device, without needing to have your smartphone with you.
2. Set Up Cellular Service (If Applicable)
If your smartwatch has cellular capabilities, you will need to activate a cellular plan. This is similar to activating a mobile phone number, and it allows you to use your smartwatch like a phone. Follow these steps to set it up:
  • Contact your carrier: Call your mobile network provider to add a smartwatch plan to your existing mobile account. Some carriers offer special plans for smartwatches.
  • Sync with your carrier: Once your smartwatch is activated with a cellular plan, pair it with your carrier's network. This usually requires going into the smartwatch's settings to enable cellular connectivity.
  • Test your connection: After activation, your smartwatch should display signal bars similar to a phone, indicating it's connected to the network.
3. Make a Call Using Your Smartwatch
Once your smartwatch is connected to a cellular network, you can make a call directly from the device.
  • Open the Phone App: Most smartwatches have a built-in dialer or phone app. Tap on the app to open it.
  • Choose a Contact or Dial a Number: You can either scroll through your contacts list, use voice commands, or manually input a phone number.
  • Make the Call: Once you've selected the contact or entered the number, tap the call button to initiate the call. Your smartwatch will use its cellular connection to dial the number.
Some smartwatches also support voice dialing. Simply press and hold the voice assistant button (like Siri or Google Assistant) and say something like, “Call [contact name].”
4. Answer Incoming Calls
When someone calls you, your smartwatch will vibrate or ring. Here's how you can answer:
  • Swipe or Tap: Depending on the model, you may need to swipe or tap on the incoming call notification to answer the call.
  • Use a Bluetooth Headset or Speaker: While some smartwatches come with built-in speakers and microphones, using a Bluetooth headset can enhance sound quality and privacy during the call.
5. Ensure Optimal Call Quality
To ensure the best call experience, consider these tips:
  • Network Strength: Calls made on a smartwatch are dependent on a strong cellular signal. Ensure you have good reception, especially in areas where the signal might be weak.
  • Use Bluetooth for Better Sound: The built-in speaker on a smartwatch can work for quick calls, but for better audio clarity, use a Bluetooth earbud or headset.
  • Battery Life: Cellular usage can drain battery life more quickly, so keep an eye on your battery levels, especially when making long calls.
6. Troubleshooting Tips
If you're having trouble making calls from your smartwatch, here are a few troubleshooting steps:
  • Check Cellular Connection: Make sure your smartwatch is properly connected to the carrier's network. If needed, restart the device and check if the cellular connection is re-established.
  • Ensure Bluetooth is Disabled: If your smartwatch is paired with your phone via Bluetooth, disconnect it before making calls independently.
  • Update Your Device: Ensure your smartwatch's software is up-to-date, as updates can improve call functionality and fix connectivity issues.
Conclusion
Making calls on a smartwatch without needing your phone is a convenient feature, especially for those who want to stay connected while on the go. By ensuring that your smartwatch has cellular connectivity, setting up a cellular plan, and following the steps above, you can easily make and receive calls directly from your wrist. Whether you're out for a run, at the gym, or simply prefer to leave your phone at home, your smartwatch will keep you connected.
190
Prev article: How to pair a Roku remote without pairing button?
Next article: Can you root your tablet? How to root?
