  2. How To
  3. How to safely remove a data cable between the cellphone and computer?
2024-12-16 1741 4
Welcome to Blackview blog. Hope the guide helps.
Phone and PC
Safely disconnecting your phone from your computer is crucial to prevent data corruption. Let's walk you through the step-by-step process to ensure a smooth and secure disconnection.
For Windows:
Stop Data Transfer: Ensure that any data transfer between your smartphone and computer is completed. This includes copying files, backing up data, or synchronizing.
Eject the Device:
  • Go to the System Tray on the bottom-right corner of your screen.
  • Click on the USB icon (it might look like a small USB plug with a checkmark).
  • Select "Eject [Your Device Name]" from the list. You'll see a message saying it's safe to remove the device.
  • Unplug the Cable: Once you see the confirmation that it's safe to remove, gently unplug the USB cable from both your smartphone and computer.
For macOS:
Stop Data Transfer: Make sure no files are being transferred between your smartphone and your Mac.
Eject the Device:
  • Open Finder and locate your smartphone under the Devices section.
  • Click the eject button next to your device's name.
  • Wait for your device to disappear from the Finder.
  • Unplug the Cable: After safely ejecting the device, you can unplug the cable from both your smartphone and your computer.
General Tips:
  • Avoid pulling the cable abruptly: Always hold the connector (the part that plugs into the port) rather than pulling the cable itself to avoid damaging the cable or the ports.
  • Ensure no ongoing operations: Make sure no apps are actively using the connection for tasks like backups or syncing before unplugging.
  • Use quality cables: Poor-quality cables can damage your devices. Always use cables that are in good condition and preferably certified by the device manufacturer.
Following these steps will ensure that your devices and data remain safe.
4
Prev article: How to prevent a cellphone screen from scratches or cracking?
Next article: [Full Guide] How to hide & unhide a WiFi network?
