Easy way to hide or unhide a WiFi network
Welcome to Blackview (Well-known brand of rugged IP68 phones, tablets, and wifi only tablets, etc.) blog. Hope the guide helps.
Ever feel the need for a little extra privacy on your home WiFi network? Don't want other mobile phones and tablets to connect to your WiFi? Hiding your SSID (network name) can be a simple way to deter casual snooping. This guide explores the process of hiding and unhiding your WiFi network on most routers, along with the pros and cons to consider.
Why Hide Your WiFi Network?
- Enhanced Security (Perception): Smartphone users can easy to connect some visible WiFi networks in some situations. A hidden network might discourage casual attempts to access your WiFi, but it doesn't guarantee complete security. Encryption is still essential.
- Reduced Network Clutter: Hiding your network name can declutter the WiFi list on your devices, especially in crowded apartment buildings.
Things to Consider Before Hiding:
- Limited Effectiveness: Hiding your SSID doesn't prevent someone with technical knowledge from finding and accessing your network if they have the necessary tools. Besides, some Wi-Fi detect phone apps also can crack some WiFi networks.
- Inconvenience for Authorized Devices: You'll need to manually enter the network name (SSID) and password every time you connect a new device to your WiFi.
How to Hide & Unhide Your WiFi Network (General Steps):
1. Access Your Router's Interface:
- Connect to your WiFi network.
- Open a web browser and enter your router's IP address in the address bar. This IP address is usually printed on the back of your router or in its manual.
- Log in to your router's interface using the username and password (also typically found on the router or manual).
2. Hiding the Network (Steps might vary depending on your router model):
- Look for a section labeled "Wireless Settings," "WiFi Settings," or similar.
- Find the option to "Hide SSID," "Broadcast SSID," or a similar setting.
- Disable the "Broadcast SSID" option (or enable "Hide SSID" if applicable).
- Save your changes.
3. Unhiding Your WiFi Network (Steps might vary):
- Follow the same steps as above to access your router's interface.
- Locate the WiFi settings section.
- Enable the "Broadcast SSID" option (or disable "Hide SSID").
Remember: The specific steps and menu options might differ depending on your router model and manufacturer. Refer to your router's manual or the manufacturer's website for detailed instructions.
Extending reading,
Additional Tips
- Strong Password is Key: Regardless of whether your network is hidden or not, using a strong and unique password for your WiFi network is crucial for optimal security.
- Enable WPA2 Encryption: Most modern routers support WPA2 encryption, which scrambles data transmitted over your WiFi network. This adds a layer of security beyond hiding your SSID.
- Guest Network (Optional): Consider creating a separate guest network with a different password for visitors. This allows them internet access without exposing your main network.
Read also,
