  3. Tech & News
  5. IP Rating and Military Grade: A Comprehensive Guide
2023-06-25 1795 0
Rugged phones are designed to withstand harsh conditions, such as dust, water, and extreme temperatures. They are often used by people who work in demanding environments, such as construction workers, firefighters, and soldiers.
Rugged phones
There are two main standards that are used to measure the ruggedness of a phone: IP rating and military grade.
IP Rating
IP rating stands for "Ingress Protection". It is an international standard that measures the protection of an electronic device against solid objects and water. The IP rating is a two-digit number, with the first digit indicating the level of protection against solid objects and the second digit indicating the level of protection against water.
Military Grade
Military grade is a term that is used to describe products that have been tested and certified to meet the standards set by the US military. The military has a number of different standards for ruggedness, but the most common one is MIL-STD-810G.
MIL-STD-810G is a comprehensive standard that tests products for a wide range of environmental conditions, including dust, water, extreme temperatures, vibration, and shock. Products that meet the MIL-STD-810G standard are considered to be very rugged. There is also a higher grade which named MIL-STD-810H, both the MIL-STD-810G phones and MIL-STD-810H phones are tough enough to withstand harsh conditions.
Comparison of IP Rating and Military Grade
IP rating and military grade are both important standards for rugged phones. IP rating measures the protection against dust and water, while military grade measures the protection against a wider range of environmental conditions.
In general, IP rating is a better measure of protection against dust and water. However, military grade is a better measure of overall ruggedness.
Conclusion
The best standard for you depends on your needs. If you are looking for a phone that is completely protected against dust and water, then an IP68 rating is a good option. If you are looking for a phone that is very rugged and can withstand a wide range of environmental conditions, then a military grade phone is a good option.
Related,
Additional Information
In addition to IP rating and military grade, there are a number of other factors to consider when choosing a rugged phone. These factors include the phone's battery life, screen size, processor, and camera.
It is also important to consider the phone's price. Rugged phones can be more expensive than regular phones, but they are worth the investment if you need a phone that can withstand harsh conditions.
Prev article: How do Apps work on Android?
Next article: MediaTek Helio G99 vs Snapdragon 680: Which one is better SoC?
You might also like:
