  2. Tech News
  3. How thermography used for home inspection?
2023-08-17 590 0
Welcome to Blackview (The famous producer of rugged tablets and phones) blog.
Infrared thermography
When you bought a thermal camera smartphone, it can be used to do many things, one example is home inspection. Thermography, also known as infrared thermography, is the use of infrared radiation (heat) to create an image of an object or area. This technology can be used to detect a variety of problems in a house (You will need a night vision camera phone if you want to find if there are hidden cameras in your house), including:
  • Heat loss. Thermography can be used to identify areas of a house that are losing heat, such as around windows and doors, or in the attic or crawlspace. This information can be used to improve the insulation in these areas and reduce energy costs.
  • Moisture problems. The thermal camera can also be used to detect moisture problems, such as leaks in the roof or plumbing, or water damage to the foundation. This information can be used to prevent further damage and costly repairs.
  • Electrical problems. Thermography can be used to detect electrical problems, such as overloaded circuits or faulty wiring. This information can help to prevent fires and other electrical hazards.
  • Structural problems. Thermography can also be used to detect structural problems, such as cracks in the foundation or walls. This information can help to identify potential problems early on and prevent them from becoming more serious.
In addition to these specific uses, thermography can also be used to get a general overview of the condition of a house. This information can be helpful for homeowners who are considering buying or selling a house, or for homeowners who want to make sure their house is in good condition.
If you are thinking about having a thermography inspection of your house, it is important to choose a qualified inspector. The inspector should have experience using thermal imagers and should be familiar with the different types of problems that can be detected with this technology.
Here are some of the benefits of using thermography for house detecting:
  • It is a non-destructive testing method, meaning that it does not damage the house.
  • It can be used to detect problems that are not visible to the naked eye.
  • It can be used to detect problems early on, before they cause more serious damage.
  • It can be used to get a general overview of the condition of a house.
If you are concerned about the condition of your house, or if you are thinking about buying or selling a house, thermography inspection is a valuable tool that can help you make informed decisions.
Prev article: MediaTek Filogic 360 Wi-Fi 7 Chip Certified by Wi-Fi Alliance
Next article: A look at Dimensity 900 and its Antutu score
