  3. Tech & News
  5. How does wireless/induction charging work? (Ultimate guide)
2023-09-08 1329 0
Welcome to Blackview (A world's well-known brand of rugged phones) blog.
Wireless charging has become a popular and convenient way to power up our devices without the hassle of cables and connectors. In this ultimate guide, we will delve into the fascinating world of wireless charging, exploring its underlying technology, and how it has revolutionized the way we charge our devices.
Wireless charger
Short answer: Wireless or induction charging works through electromagnetic fields. A charging pad contains a coil that generates an electromagnetic field when powered. When a compatible device, like a smartphone, is placed on the pad, its receiver coil converts the electromagnetic field back into electrical energy, which then charges the device's battery. The process is based on inductive coupling, where energy is transferred between coils through magnetic induction, allowing power to flow without the need for a physical connection like a cable.
Understanding Wireless Charging:
Wireless charging, also known as inductive charging or cordless charging, is a method of transferring power from a charging pad charger or station to a compatible device without the need for physical cables or direct electrical contacts. It relies on electromagnetic fields to transfer energy wirelessly.
Inductive Charging Technology:
Wireless charging utilizes electromagnetic induction to transfer power. The charging pad charger or station contains a transmitter coil that generates an alternating current (AC) magnetic field. The device being charged, equipped with a receiver coil, converts this magnetic field back into electrical current to charge the battery.
Key Components:
  • a. Transmitter Coil: The charging pad or station houses the transmitter coil, which generates the alternating magnetic field. When connected to a power source, it produces an oscillating current that creates the necessary magnetic field for charging.
  • b. Receiver Coil: The device being charged features a receiver coil, typically integrated into the back or bottom of the device. This coil acts as an antenna, capturing the magnetic field generated by the transmitter coil and converting it back into electrical energy.
  • c. Control Circuitry: Both the charging pad and the device being charged contain control circuitry that manages the power transfer process. This circuitry ensures efficient energy transfer, regulates the charging current, and provides safety features such as temperature monitoring and overcharge protection.
Charging Efficiency and Standards:
Wireless charging efficiency can vary depending on factors such as coil design, alignment, and distance between the transmitter and receiver coils. Different wireless charging standards, such as Qi (pronounced "chee"), have been established to ensure compatibility and optimize charging performance across various devices.
Applications:
  • a. Convenience: Wireless charging eliminates the need for cables and connectors, providing a hassle-free charging experience. Simply placing a compatible device on a charging pad initiates the charging process.
  • b. Device Longevity: Wireless charging reduces wear and tear caused by repeatedly plugging and unplugging cables, potentially extending the lifespan of charging ports on devices.
  • c. Versatility: Wireless charging can be integrated into various devices, such as smartphones, Android smart watches, TWS earbuds, and even electric vehicles. It offers a universal charging solution for multiple devices.
  • d. Design Freedom: The absence of physical connectors allows for sleek and minimalist device designs, as manufacturers can eliminate charging ports and create more rugged, water-resistant devices.
Wireless charging
Limitations and Considerations:
  • a. Charging Speed: Wireless charging is generally slower compared to traditional wired charging methods. However, advancements in technology have led to faster wireless charging options.
  • b. Distance and Alignment: The device needs to be properly aligned with the charging pad charger for efficient charging. Misalignment or obstacles between the coils can lead to reduced charging efficiency.
  • c. Heat Generation: Wireless charging can generate heat during the charging process. Manufacturers incorporate thermal management systems to maintain safe charging temperatures.
  • Read details of advantages and disadvantages of wireless charging.
Future Developments:
Wireless charging technology continues to evolve, with ongoing efforts to improve charging speed, efficiency, and compatibility across different devices. Innovations such as extended-range wireless charging and the integration of wireless charging in public spaces are being explored.
Conclusion
Wireless charging has transformed the way we power up our devices, offering convenience, versatility, and design flexibility. By harnessing the power of electromagnetic induction, wireless charging provides a cable-free charging experience. As technology advances, we can expect further improvements in charging speed, efficiency, and compatibility, making wireless charging an integral part of our daily lives.
Extended reading,
Prev article: A quick look at what is Wi-Fi 7
Next article: What does Magnetic sensor use for in smartphones?
