  2. Tech News
  3. Unveiling the Fold: How Foldable Phones Work
2024-05-14 700 0
Foldable phones, with their ability to transform from a compact phone to a tablet-sized display, are redefining the mobile experience. But have you ever wondered how these technological marvels actually work? Let's delve into the key components that bring foldable phones to life.
Foldable Phones
Short answer: Foldable phones use flexible OLED or AMOLED displays that bend without breaking, thanks to advanced materials like ultra-thin glass or plastic. Special hinge mechanisms enable smooth folding and unfolding. The software adjusts automatically, allowing seamless transitions between folded and unfolded modes, adapting the interface for multitasking and expanded viewing. Batteries, wiring, and other components are strategically divided to accommodate the foldable design.
The Hinge: The Backbone of Flexibility
The hinge is the foldable phone's crown jewel. It's a complex mechanism that allows the phone to smoothly open and close without damaging the display. Here's a breakdown of its key features:
  • Multi-Link Design: Many hinges utilize a multi-link system, employing several interlocking gears and components. This intricate design ensures smooth folding and distributes pressure evenly, minimizing stress on the display.
  • Hidden Gears: The gears and mechanisms of the hinge are often hidden within the phone's body. This not only protects them from damage but also maintains a sleek aesthetic.
  • Durability Enhancements: Manufacturers incorporate features like dust-resistant brushes into the hinge to prevent debris from entering and causing potential damage.
Blackview Hero 10
The Flexible Heart: The Foldable Display
Unlike traditional glass displays, foldable phones rely on OLED (Organic Light-Emitting Diode) technology. OLED panels are naturally thin and flexible, making them perfect for folding. However, pure glass wouldn't hold up to the constant bending. That's where advancements in display technology come in.
Modern foldable phones utilize a plastic substrate instead of glass. This plastic base is much more flexible but also more susceptible to scratches. To address this, manufacturers apply a thin layer of ultra-thin glass (UTG) or a specially designed flexible plastic layer on top for improved scratch resistance (Of course, it is unable to compare with the rugged smartphone).
Software Optimization: Adapting to a New Form Factor
The magic of a foldable phone isn't just hardware; software plays a crucial role too. The operating system needs to be optimized to recognize the phone's different states (folded or unfolded) and adjust the interface accordingly.
For instance, apps might automatically switch to a tablet-like layout when the phone is unfolded, providing a more immersive experience. Additionally, the software can be programmed to prevent accidental touches on the crease area when folded. Here is the breakdown:
  • Multi-Window Functionality: Many foldable phones take advantage of the larger unfolded display by allowing you to run multiple apps simultaneously in resizable windows.
  • App Continuity: The software can intelligently adjust the layout of an app based on whether the phone is folded or unfolded. This ensures a smooth transition between phone and tablet modes.
  • Gesture Recognition: Some foldable phones utilize specific gestures to take advantage of the unique form factor. For example, a swipe across the crease might launch a specific app in split-screen mode.
Beyond the topic
In conclusion, foldable phones are marvels of engineering that combine a complex hinge, a flexible display, and optimized software. While they continue to evolve, understanding these core components provides a glimpse into the magic that unfolds with every use.
Prev article: Smart work assistant on Android: Google AI provides 3 new ways
Next article: How durable is a foldable smartphone?
