  2. Tech News
  3. How does FM radio work in smartphones?
2024-01-30 1451 17
Welcome to Blackview (Well-known brand of outdoor rugged smartphone) blog. Hope the guide helps.
FM in smartphones
FM radio in mobile phones works by utilizing the built-in FM radio receiver and antenna present in the device. Here's a general overview of how FM radio works in mobile phones:
  • FM Radio Receiver: Mobile phones that support FM radio have a dedicated FM radio receiver chip. This chip is responsible for receiving FM radio signals and converting them into audio signals that can be played through the phone's speakers or headphones.
  • Antenna: The mobile phone has an internal FM radio antenna, usually integrated into the device's headphone wire or acting as a separate antenna. The antenna helps capture FM radio signals from the airwaves.
  • Frequency Tuning: The user can access the FM radio feature through a dedicated app or the phone's default radio app. When the app is launched, the FM radio receiver tunes to a specific frequency on the FM band.
  • Signal Reception: The FM radio receiver captures the FM radio signals transmitted by radio stations. These signals are electromagnetic waves that carry audio information. The receiver uses the antenna to capture the radio waves in the air.
  • Demodulation: After capturing the radio signals, the FM radio receiver demodulates them. Demodulation separates the audio information from the carrier wave. In FM radio, the carrier wave's frequency is modulated based on the audio signal's variations (such as voice or music).
  • Audio Playback: Once the audio information is demodulated, it is sent to the phone's audio system for playback. The audio can be heard through the phone's built-in speakers or connected headphones. Users can control the volume and switch between different FM radio stations using the app's interface.
It's important to note that FM radio on mobile phones requires an active FM radio signal from a local radio station. This means that you might need to connect headphones to act as an antenna, as they often have the necessary wiring to serve as an FM antenna. Additionally, FM radio in mobile phones does not require an internet connection, as it relies on receiving broadcast signals directly from FM radio stations.
It's worth mentioning that not all mobile phones have FM radio capabilities, as it depends on the phone's hardware and manufacturer's specifications. Therefore, it's recommended to check the phone's specifications or consult the manufacturer to verify if the device supports FM radio.
Related,
17
Prev article: A Look at Dimensity 9300 Release Date and Main Features
Next article: What type of electronic gadgets will replace smartphones in future?
