  2. Tech News
  3. What does 4G+ (LTE-Advanced, LTE-A) mean on the phone?
2023-07-21 7228 100
The ultimate guide of 4G+ network.
Welcome to Blackview blog. Blackview, one of the famous rugged phones brands around the world.
The 4G network is the fourth generation of cellular network technology, and it offers a significant improvement over the previous generation, 3G. 4G networks are capable of delivering much faster data speeds, which can be used for streaming video, downloading large files, and playing online games.
4G+
If you've been using a smartphone for a while, you've probably noticed that the signal bars on your phone sometimes show "4G+" instead of just "4G." But what does that extra "+" mean? And is it actually any faster than regular 4G?
In this guide, we'll answer those questions and explain what 4G+ is all about.
What is 4G+?
The 4G+ is also known as LTE-Advanced or LTE-A. 4G+ is a marketing term used by some mobile carriers to refer to their 4G LTE networks that have been enhanced with additional features, ie, the 4G+ network is an enhanced version of the 4G network that offers faster data speeds and better performance. 4G+ networks use a variety of technologies to achieve faster speeds, including carrier aggregation, which allows a phone to connect to multiple LTE bands at the same time, and MIMO (multiple input, multiple output), which uses multiple antennas to improve data speeds, and 4×4 MIMO.
What is carrier aggregation?
Carrier aggregation is a technology that allows multiple LTE bands to be combined to create a wider bandwidth. This results in faster data speeds. For example, a 4G+ network that uses carrier aggregation with three LTE bands could achieve a theoretical data speed of up to 300 Mbps.
What is MIMO?
MIMO stands for multiple-input, multiple-output. It is a technology that uses multiple antennas to transmit and receive data at the same time. This results in better performance and faster data speeds. For example, a 4G+ network that uses MIMO with four antennas could achieve a theoretical data speed of up to 1 Gbps.
What is 4×4 MIMO?
4×4 MIMO is a more advanced version of MIMO that uses four antennas to transmit and receive data at the same time. This results in even better performance and faster data speeds. For example, a 4G+ network that uses 4×4 MIMO could achieve a theoretical data speed of up to 2 Gbps.
Is 4G+ available everywhere?
4G+ is not available everywhere. It's still a relatively new technology, and it's only being rolled out in select areas by some mobile carriers. If you're not sure if 4G+ is available in your area, you can check with your carrier. Related, learn about the difference between 4G and 4G+.
How to check if your phone supports 4G+
To check if your phone supports 4G+, you can look for the "4G+" symbol in the status bar of your phone. If you see the "4G+" or "LTE+" symbol, then your phone supports 4G+. You can also check the specifications of your phone online to see if it supports 4G+.
How to get 4G+
To get 4G+, you need to have a phone that supports 4G+ and you need to be in an area with a 4G+ network. You can check the availability of 4G+ networks in your area by visiting the website of your cellular carrier.
Benefits of using 4G+
There are a number of benefits to using 4G+, including:
  • Faster data speeds: 4G+ networks offer faster data speeds than 4G networks. This means that you can download files, stream videos, and play games more quickly.
  • Better performance: 4G+ networks offer better performance than 4G networks. This means that you are less likely to experience dropped calls or slow data speeds.
  • More reliable connections: 4G+ networks offer more reliable connections than 4G networks. This means that you are less likely to lose your connection when you are moving around.
Conclusion
The 4G+ network is an enhanced version of the 4G network that offers faster data speeds and better performance. If you have a phone that supports 4G+ and you are in an area with a 4G+ network, then you can take advantage of these benefits.
Read also,
100
Prev article: What is the difference between 4G and 4G+ network?
Next article: What is Huawei SuperCharge?
