  2. Tech News
  3. What is the difference between 4G and 4G+ network?
2023-07-21 25437 391
Welcome to Blackview blog.
4G vs 4G+ in smartphone
4G and 4G+ are both fourth-generation mobile network technologies, which are widely used in all over the world. 4G is the standard version of the technology, while 4G+ is an enhanced version that offers faster data speeds.
Here are the key differences between 4G and 4G+:
  • Data speeds: 4G can offer data speeds of up to 100 Mbps, while 4G+ can offer data speeds of up to 1 Gbps (theoretical value). This means that 4G+ is about 10 times faster than 4G.
  • Carrier aggregation: 4G can only use a single band at a time, while 4G+ can use multiple bands at the same time. This allows 4G+ to achieve faster data speeds.
  • MIMO: 4G uses a single antenna to transmit and receive data, while 4G+ uses multiple antennas. This allows 4G+ to achieve faster data speeds and better coverage.
Overall, 4G+ is a faster, more advanced version of 4G. If you're looking for the best possible data speeds, 4G+ is a good option. However, it's important to note that 4G+ is not available everywhere, and you'll need a 4G+-enabled phone and a 4G+ plan from a mobile carrier that offers 4G+ service in your area.
How to Check if Your Phone is Using 4G+
Here are ways to verify if your phone is connected to 4G+:
Method 1: Check the Status Bar
  • Look at the network indicator in your phone's status bar (top of the screen)
  • Different phones/icons may show:
    • 4G+
    • LTE+
    • LTE-A
Method 2: Check Network Settings (Android)
  • Go to Settings > About phone > SIM status
  • Look for "Mobile network type" - it should say "LTE+" or "LTE Advanced"
Method 3: Use a Speed Test
  • Run a speed test (using apps like Speedtest by Ookla)
  • 4G+ typically provides speeds of 100-300 Mbps (vs 20-100 Mbps for regular 4G)
Method 4: Check Carrier Support
  • Contact your carrier to confirm if 4G+ is available in your area
  • Check your phone's compatibility with LTE Advanced bands
Important Notes:
  • 4G+ availability depends on:
    • Your carrier's network
    • Your location
    • Your phone's capabilities
  • Some phones may not clearly indicate 4G+ even when connected
Here are some additional things to keep in mind about 4G+:
  • 4G+ can be more expensive than regular 4G.
  • 4G+ doesn't always offer a significant speed boost. In some cases, you may only see a small increase in speed.
Overall, 4G+ is a good option if you want the best possible data speeds.
Read also,
391
Prev article: 4G+ vs 5G, Is it the same as 5G?
Next article: What does 4G+ (LTE-Advanced, LTE-A) mean on the phone?
