  2. Smart Life
  3. How do I convert wired Android Auto to wireless?
2025-03-28 4 0
Welcome to Blackview (Well-known China brand of cheap powerful mini PC and notebook) blog. Hope the guide helps.
Android Auto is a fantastic tool for integrating your smartphone with your car's infotainment system, but relying on a wired connection can be inconvenient. Fortunately, there are ways to convert your wired Android Auto setup to wireless, eliminating the need for cables. This guide will walk you through the steps to achieve a seamless wireless Android Auto experience.
Wired Android Auto
Check Your Device Compatibility
Before attempting to switch to wireless Android Auto, ensure your smartphone and car stereo support it. Your phone must run Android 9.0 or higher, and your car's head unit should be compatible with wireless Android Auto. Check your manufacturer's specifications or consult your vehicle's manual to confirm.
Purchase a Wireless Android Auto Adapter
If your devices are compatible, the next step is to buy a wireless Android Auto adapter. Popular options include the AAWireless and Motorola MA1. These dongles plug into your car's USB port and communicate wirelessly with your phone, mimicking a wired connection without the cable hassle.
Set Up the Wireless Adapter
Once you have the adapter, follow these steps: 1) Plug the dongle into your car's USB port. 2) Turn on your car's ignition and wait for the adapter to boot. 3) On your phone, enable Bluetooth and Wi-Fi, then open the Android Auto app. 4) Follow the on-screen prompts to pair your phone with the adapter.
Configure Android Auto Settings
After pairing, customize your Android Auto settings for optimal performance. Enable "Start Android Auto automatically" and "Wireless projection" in the app's settings. Adjust resolution and touchscreen sensitivity if needed. Ensure your phone's battery optimization settings don’t interfere with Android Auto's background operation.
Troubleshooting Common Issues
If you encounter connectivity problems, try these fixes: 1) Restart your phone and car stereo. 2) Ensure the adapter's firmware is up to date. 3) Move your phone closer to the adapter to rule out signal interference. 4) Reset the adapter and re-pair your device if issues persist.
Switching from wired to wireless Android Auto can significantly enhance your driving experience by reducing clutter and improving convenience. By following these steps, you’ll enjoy a seamless connection without the hassle of cables. Happy driving!
Prev article: How to fix HDMI stopped working on your laptop?
Next article: How to fix no sound issue on TV from connected laptop?
