  3. How To
  5. How to Fix iPhone Not Automatically Connecting to Wi-Fi?
2024-04-08 2705 4
Welcome to Blackview (Well-known brand of waterproof rugged phone) blog. Hope this guide has been helpful.
If your iPhone is not automatically connecting to familiar Wi-Fi networks, it can be inconvenient and frustrating. However, there are several troubleshooting steps you can take to resolve this issue. This guide offers solutions to get your iPhone reconnecting seamlessly. So, let's dive in, right now.
iPhone Wi-Fi reconnection
Step 1: Verify Wi-Fi Network Settings
  • Open the Settings app on your iPhone.
  • Tap on "Wi-Fi" to access Wi-Fi network settings.
  • Ensure that the Wi-Fi toggle switch is turned on.
  • Check if your desired Wi-Fi network is listed under "Choose a Network."
  • If the network is listed, tap on it and enter the password if required.
Step 2: Forget and Reconnect to Wi-Fi Network
  • In the Wi-Fi settings, locate the network causing the issue.
  • Tap on the (i) icon next to the network name.
  • Tap on "Forget This Network" and confirm your selection.
  • Restart your iPhone.
  • Go back to the Wi-Fi settings and reconnect to the network by selecting it and entering the password.
Step 3: Disable Private Wi-Fi Address
While useful for public Wi-Fi, Private Wi-Fi Address on iOS 14 and later might interfere with automatic connection on trusted networks. Try turning it off:
  • Go to Settings -> Wi-Fi.
  • Tap the information icon (i) next to the Wi-Fi network name.
  • Toggle "Private Address" to off.
Step 4: Reset Network Settings
  • Go to "General" and scroll down to find "Reset."
  • Tap on "Reset Network Settings."
  • Enter your passcode if prompted and confirm the reset.
  • After the reset is complete, reconnect to your Wi-Fi network.
Step 5: Update iOS to the Latest Version
  • Connect your iPhone to a stable Wi-Fi network.
  • Open the Settings app and go to "General."
  • Tap on "Software Update."
  • If an update is available, tap "Download and Install."
  • Follow the on-screen instructions to update your iOS version.
Step 6: Reset All Settings
  • Tap on "Reset All Settings."
  • After the reset is complete, reconfigure your Wi-Fi settings and reconnect to your network.
Extending reading: "How can I see a wifi password on my phone?" And, "How to change my WiFi password?"
Step 7: Looking for Help
If the issue persists after trying the above steps, it's recommended to contact Apple Support or visit an Apple Store or a phone repair store for further assistance. They can help diagnose and resolve any underlying hardware or software issues causing the problem.
Remember to check if the Wi-Fi network is functioning correctly by testing it with other devices. Also, ensure that the network's settings, such as DHCP and security protocols, are compatible with your iPhone.
In conclusion, if your iPhone doesn't automatically connect to Wi-Fi networks, follow these troubleshooting steps. Verify Wi-Fi settings, forget and reconnect to the network, reset network settings, update iOS, and reset all settings if necessary. If the problem persists, seek assistance from Apple Support. By taking these steps, you should be able to resolve the issue and restore automatic Wi-Fi connectivity on your iPhone.
4
Prev article: [Quick Guide] How do you add a background on Zoom?
Next article: How to hide and unhide a folder or a file on Android devices?
