  2. How To
  3. Ways on how to trick/hide from a thermal camera
2023-04-21 3155 0
Welcome to Blackview blog. Blackview, the famous brand of rugged phones in the world.
Ways to hide from thermal vision
The thermal camera phones are used in many industries such as agriculture, fire rescue, wildlife protection, law enforcement, and Pipeline Overhaul thanks to its portability and ease of use. However, thermal cameras are not perfect, and they can be fooled by certain materials and techniques.
How to trick a thermal imaging camera?
There are a few ways to hide from a thermal camera based on how thermal imaging works. One way is to use a material that does not reflect heat, such as glass or plastic. Another way is to use a material that reflects heat differently than the surrounding area, such as a black tarp or a white sheet. Finally, you can also use a thermal imaging camouflage suit, which is designed to make you appear invisible to thermal cameras.
Here are some of the materials that can be used to trick a thermal vision camera:
  • Glass: Glass does not reflect heat, so it will appear black on a thermal camera.
  • Plastic: Plastic also does not reflect heat, so it will appear black on a thermal camera.
  • Black tarp: A black tarp will reflect heat differently than the surrounding area, so it will appear as a hot spot on a thermal camera.
  • White sheet: A white sheet will reflect heat differently than the surrounding area, so it will appear as a cold spot on a thermal camera.
  • Thermal imaging camouflage suit: A thermal imaging camouflage suit is designed to make you appear invisible to thermal vision. These suits are typically made of materials that do not reflect heat, or that reflect heat differently than the surrounding area.
It is important to note that thermal imaging cameras are not perfect, and they can be fooled by certain materials and techniques. However, by using the materials and techniques listed above, you can make it more difficult for a thermal imaging to detect you.
Related,
Prev article: How to know if the Other Party Blocked Your Number?
Next article: How do firefighters use thermal imaging?
