  2. How To
  3. 3 Easy ways for How to clean your clear phone case that turned yellow
2023-03-22 97433 503
Diffuse it if you think it is useful. The greatest affirmation for our efforts is your sharing.
If you are using a rugged smartphone - the device with drop-, water-, shock-, cold-, and dust-resistant, you won't need a phone cover. If you using a regular phablet, you might need it. If you have a transparent phone case that has turned yellow, it can be frustrating to look at and may even make your phone appear dirty. However, there are several simple methods you can use to clean your clear phone case and restore its original color, to instead of getting a new phone cover. So, let's take a look right now.
Method 1: Using Baking Soda and Water
One of the most effective ways to clean a clear phone case that has turned yellow is by using baking soda and water. Here are the steps:
1. Mix one tablespoon of baking soda with one cup of warm water in a bowl.
2. Take your clear phone case off your phone and place it in the bowl with the baking soda mixture.
3. Let the case soak for about 30 minutes.
4. After 30 minutes, remove the case from the bowl and rinse it thoroughly with warm water.
5. Dry the case with a soft cloth or paper towel.
Method 2: Using Hydrogen Peroxide
Another effective way to clean a clear phone case that has turned yellow is by using hydrogen peroxide. Here are the steps:
1. Take your transparent phone case off your phone and place it in a bowl.
2. Pour enough hydrogen peroxide over the case to fully submerge it.
Hydrogen Peroxide
Method 3: Using Toothpaste
Toothpaste is also an effective way to clean a clear phone case that has turned yellow. Here are the steps:
1. Take your clear phone case off your phone and place it on a clean surface.
2. Apply toothpaste to the yellowed areas of the case.
3. Use a soft-bristled toothbrush to gently scrub the toothpaste into the case for about two minutes.
4. Rinse the case thoroughly with warm water.
Toothpaste
Read also,
503
Prev article: How to fix when your iPhone was frozen and won't turn off or reset
Next article: Easy ways for How to Fix iPhone Black Screen of Death
