  2. Tech News
  3. What is VOOC Flash Charge?
2023-07-17 1422 7
The ultimate guide about VOOC Flash Charge.
Welcome to visit Blackview blog. Blackview is a well-known rugged phones brand in the world.
VOOC Flash Charge
VOOC Flash Charge is a fast charging technology developed by OPPO Electronics. It was first introduced in 2014 and has since been updated several times. VOOC Flash Charge uses a higher voltage and lower current than traditional fast charging technologies, which allows it to charge devices more quickly without overheating.
VOOC Flash Charge is compatible with a wide range of OPPO smartphones, including the Find X5 Pro, Reno6 Pro 5G, and Find X3 Lite. It can also be used to charge other devices, such as laptops and tablets.
Here are some of the benefits of using VOOC Flash Charge:
  • It can charge devices much more quickly than standard USB charging.
  • It is relatively safe, as it uses power management features to prevent devices from being overcharged.
  • It is compatible with a wide range of devices.
Here are some of the different versions of VOOC Flash Charge:
  • VOOC 1.0: This was the first version of VOOC Flash Charge and it was released in 2014. It could charge devices at a rate of up to 50W.
  • VOOC 2.0: This version was released in 2016 and it could charge devices at a rate of up to 65W. Read also, the 6 best 65W fast charging mobiles in 2023.
  • VOOC 3.0: This version was released in 2019 and it could charge devices at a rate of up to 80W.
  • Super VOOC: This is the latest version of VOOC Flash Charge and it was released in 2020. It can charge devices at a rate of up to 120W. Related, check out the nowadays world fastest charging phone list.
Super VOOC is the fastest version of VOOC Flash Charge and it can charge a smartphone from empty to full in just 15 minutes. However, it is only available on a limited number of devices.
7
Prev article: What is OnePlus Dash Charging?
Next article: What does PD fast charge mean?
You might also like:
