  2. Tech News
  3. Is Windows 11 Pro difficult to use?
2023-06-02 512 0
Welcome to Blackview blog.
Windows 11 Pro
Whether or not Windows 11 Pro is difficult to use depends on your individual preferences and experience with previous versions of Windows. However, overall, it is not difficult to use. Some users may find the new interface and features to be challenging, while others may find them to be more intuitive and user-friendly.
Here are some of the things that some users may find difficult about Windows 11 Pro:
  • The new Start menu is located in the center of the taskbar, which may be jarring for users who are used to it being in the bottom-left corner.
  • The taskbar is now more customizable, but this can also make it more difficult to find what you're looking for.
  • Some features, such as the Action Center, have been moved to different locations.
  • The new Snap Layouts feature can be helpful for organizing your windows, but it can also be confusing at first.
Overall, Windows 11 Pro is a major change from previous versions of Windows. Some users may find it difficult to adjust to the new interface and features, while others may find them to be more intuitive and user-friendly. If you're not sure whether or not you're ready to upgrade to Windows 11 Pro, you may want to consider running the Windows 11 Insider Preview to see how you like it.
Here are some tips for making the transition to Windows 11 Pro easier:
  • Take some time to explore the new interface and features.
  • Read the Windows 11 documentation and watch tutorials.
  • Ask for help from a friend or colleague who is already using Windows 11 Pro.
  • Be patient and don't be afraid to experiment.
Prev article: IP69 Waterproof Protection: Everything you want to know
Next article: 5G: The Key to Connecting MR Smart Glasses to Smartphones
You might also like:
