  2. Tech News
  3. Is Helio G99 popular than Snapdragon 732G in the market?
2023-06-13 505 0
Snapdragon 732G
As of June 2023, the Snapdragon 732G is more popular than the Helio G99 in the market. According to Counterpoint Research, the Snapdragon 732G was used in 10.5% of all smartphones shipped in Q1 2023, while the Helio G99 was used in just 2.5% of shipments. There are a few reasons for this difference in popularity.
First, the Snapdragon 732G is a more powerful processor. It has a faster CPU and GPU, which makes it better suited for gaming and other demanding tasks. The Helio G99 is still a capable processor, but it's not as powerful as the Snapdragon 732G.
Second, the Snapdragon 732G is more widely available. It's used in a wider range of smartphones from different manufacturers, which makes it easier for consumers to find a phone with this processor. The Helio G99 is only used in a limited number of smartphones such as rugged phones, which makes it less accessible.
Third, the Snapdragon 732G is more expensive than the Helio G99. This is because Qualcomm charges a premium for its Snapdragon processors. MediaTek, on the other hand, sells its Helio processors at a lower price point. This makes the Helio G99 a more affordable option for consumers on a budget. For example, the Blackview BV9300 Pro is a budget rugged phone with good performance that make it popular in the market.
However, the Helio G99 does have some advantages over the Snapdragon 732G. It is cheaper and has a longer battery life. It also has a better camera, thanks to its 64MP sensor.
Overall, the Snapdragon 732G is a more popular processor than the Helio G99. It's more powerful, widely available, and slightly more expensive. If you're looking for a powerful and versatile smartphone, the Snapdragon 732G is a great option. If you're on a budget, the Helio G99 is still a capable processor that can handle most tasks. Here is the compare guide - Helio G99 vs Snapdragon 732G - ready for you.
Prev article: Thermal Cameras in Law Enforcement
Next article: Helio G99 vs Snapdragon 732G: Which is the better SoC?
