  2. Tech News
  3. See how the Active 8 Pro survived on a construction site
2023-06-29 307 0
Construction sites are some of the most demanding environments in the world. They are full of hazards, from falling objects to hazardous materials. This makes it essential for workers to have durable and reliable equipment.
Blackview Active 8 Pro
The Blackview Active 8 Pro is a rugged tablet that is designed to withstand the harsh conditions of a construction site. It is IP68 and IP69K rated, which means it is dustproof, waterproof, and can withstand being submerged in water for up to 30 minutes. It is also MIL-STD-810H certified, which means it can withstand extreme temperatures, shock, vibration, and sand and dust.
To test the durability of the Active 8 Pro, we took it to a construction site and put it through a series of challenges. We dropped it from a height of 6 feet, submerged it in mud, grout, and water, and exposed it to dust, bricks, concrete, and debris.
The Active 8 Pro survived all of these challenges without a scratch. The screen didn't crack, the buttons didn't stick, and the watertight seals didn't leak. We were impressed with how well the Active 8 Pro performed in such harsh conditions.
Here are some of the specific challenges we put the Active 8 Pro through:
  • Drop test: We dropped the Active 8 Pro from a height of 6 feet onto concrete. The tablet landed face down and bounced once before coming to a stop. There was no damage to the screen or the body of the tablet.
  • Waterproof test: We submerged the Active 8 Pro in a bucket of water for 30 minutes. The tablet continued to work perfectly and there was no water damage.
  • Dustproof test: We covered the Active 8 Pro in a thick layer of dust. We then shook the tablet vigorously and blew on it. The dust did not get inside the tablet and it continued to work perfectly.
  • Vibration test: We placed the Active 8 Pro on a vibrating platform and turned it on high. The tablet vibrated for 30 minutes and there was no damage to the screen or the body of the tablet.
  • Impact test: We hit the Active 8 Pro with a hammer. The tablet sustained some minor cosmetic damage, but it continued to work perfectly.
Overall, we were very impressed with the durability of the Blackview Active 8 Pro. It is a rugged tablet that can withstand the harsh conditions of a construction site. If you are looking for a tablet that can take a beating, the Active 8 Pro is a great option.
In addition to its durability, the Active 8 Pro also has a number of features that make it ideal for use on a construction site. It has a large, bright display that is easy to see in sunlight. It also has a long battery life, so you can use it all day without having to worry about running out of power. And, because it is rugged, you don't have to worry about damaging it if it gets dropped or wet.
Here are some of the other features that make the Active 8 Pro ideal for use on a construction site:
  • Long battery life: The Active 8 Pro has a large 22,000mAh solid-state battery that can last up to 1440 hours on standby. This means you can use it all day long without having to worry about running out of power.
  • Rugged design: The Active 8 Pro is MIL-STD-810H certified, which means it can withstand extreme temperatures, shock, vibration, and sand and dust. This makes it perfect for use in harsh environments like construction sites.
  • Large display: The Active 8 Pro has a large 10.36-inch display that is easy to see in sunlight. This makes it perfect for using on a construction site, where you often have to work in bright sunlight.
  • Waterproof and dustproof: The Active 8 Pro is IP68 and IP69K rated, which means it is dustproof, waterproof, and can withstand being submerged in water for up to 30 minutes. This makes it perfect for use in wet or dusty environments.
  • Rear camera with flash: The Active 8 Pro has a rear camera with flash, which is perfect for taking photos or videos in low-light conditions. This can be helpful on a construction site, where you often have to work in dark or dimly lit areas.
  • Front-facing camera: The Active 8 Pro also has a front-facing camera, which is perfect for making video calls or taking selfies. This can be helpful for communicating with colleagues or clients on a construction site.
Overall, the Active 8 Pro is a ruggedized tablet that is designed to withstand the harsh environments of a construction site. It is dustproof, waterproof, and shockproof, making it ideal for use in any condition. It also has a number of features that make it ideal for construction workers, such as a large display, a long battery life. If you are looking for a tablet that can withstand the rigors of construction work, the Blackview Active 8 Pro is a great option. Click here to get one (World premiere on 2023.7.10 PST).
Read also,
Prev article: Windows 10 vs 11, Is Windows 11 better than Wins 10?
Next article: How do Apps work on Android?
