  2. Smart Life
  3. How do I connect Samsung TV to Wi-Fi without remote?
2025-02-14 787 6
Welcome to Blackview (Well-known brand of rugged tablet and smartphone) blog. Hope the guide helps.
Connecting your Samsung TV to Wi-Fi is essential for accessing streaming services, apps, and online content. However, if you've misplaced your remote, the process might seem challenging. Don't worry—this guide will walk you through alternative methods to connect your Samsung TV to Wi-Fi without a remote. Whether you use a mobile app, physical buttons, or other tools, you'll be back online in no time.
Samsung TV
Method 1: Use the Samsung SmartThings App
The Samsung SmartThings app is a convenient way to control your TV without a remote. Here's how to use it:
1. Download and install the SmartThings app on your smartphone or tablet from the Google Play Store or Apple App Store.
2. Ensure your phone and Samsung TV are connected to the same Wi-Fi network.
3. Open the app and follow the on-screen instructions to add your TV as a device.
4. Once connected, use the app's virtual remote to navigate to the TV's settings and connect to your desired Wi-Fi network.
Method 2: Use the TV's Physical Buttons
Most Samsung TVs have physical buttons located on the back or side of the screen. Here's how to use them:
1. Locate the power button, volume buttons, and channel buttons on your TV.
2. Press the power button to turn on the TV.
3. Use the volume and channel buttons to navigate the on-screen menu. For example, press the volume up button to move up and the volume down button to move down.
4. Navigate to the "Network" or "Wi-Fi" settings and select your preferred network. Enter the password using the on-screen keyboard.
Method 3: Use a Universal Remote
If you have a universal remote, you can program it to work with your Samsung TV. Follow these steps:
1. Turn on your Samsung TV and the universal remote.
2. Find the setup instructions for your universal remote (usually in the manual or online).
3. Enter the code for Samsung TVs to pair the remote with your TV.
4. Once paired, use the remote to navigate to the Wi-Fi settings and connect to your network.
Method 4: Use a USB Keyboard or Mouse
If your Samsung TV has a USB port, you can connect a USB keyboard or mouse to control it:
1. Plug the USB keyboard or mouse into the TV's USB port.
2. Use the keyboard or mouse to navigate to the TV's settings menu.
3. Select the Wi-Fi option and choose your network. Enter the password using the keyboard.
Method 5: Borrow a Remote Temporarily
If none of the above methods work, consider borrowing a remote from a friend or family member with a Samsung TV:
1. Pair the borrowed remote with your TV by pointing it at the TV and pressing the power button.
2. Use the remote to access the Wi-Fi settings and connect to your network.
3. Return the remote once the setup is complete.
In conclusion, losing your Samsung TV remote doesn't mean you can't connect to Wi-Fi. By using the SmartThings app, physical buttons, a universal remote, a USB keyboard, or even borrowing a remote, you can easily get your TV back online. Try these methods and enjoy uninterrupted access to your favorite content!
6
Prev article: How to make your house a smart home?
Next article: Can Samsung Watches work with Google Pixel phones?
