  2. Tech News
  3. Movavi Online Audio Converter Review: Interface and Workflow (User Experience)
2024-04-16 30 0
Converting audio files is a common task for many people, whether it's for personal or professional use. We use audio converters to change the file format, quality, or size of our audio files. The thing is, nowadays, we have a vast number of options to choose from.
Audio Converter
Traditional software or desktop applications are a go-to option for many as they offer more features and control over the conversion process. However, with the rise of cloud-based technology, online converters have become a popular choice due to their convenience, accessibility, and ease of use.
In this review, I'll take a closer look at Movavi Online Audio Converter, an online tool for converting audio files with a click of a button.
Movavi Online Audio Converter Overview
Movavi is better known for its desktop software, including video editing, screen recording, and video conversion. However, there is also an online option for each of these tools.
Movavi Online Audio Converter is a free easy tool that allows you to change any video format or audio files without the need for any software installation, dealing with confusing interfaces, watching annoying ads, or paying for premium features.
And when I say easy, that's accurately what this tool is. No clunky and complicated settings, no overwhelming options — just a straightforward and intuitive workflow.
Everything happens on one page without the need for multiple tabs or redirects. And you can use it on any device, whether you're on a Windows, Mac, Android, or iOS platform.
As for the supported formats, Movavi Online Audio Converter covers the most popular ones, such as MP3, WAV, FLAC, M4A, MKA, and more.
How Does Movavi Online Audio Converter Work?
Using online audio converter by Movavi is a breeze. You don't even need to be tech-savvy to figure it out. Here's a step-by-step guide on how you can convert your audio files effortlessly:
Step 1. First, visit the Movavi Online Audio Converter website. On the right side of the page, you'll see a box with options to convert or compress your files. Depending on your needs, pick the appropriate option.
Step 1
Step 2. Next, click 'Add Your Media' and select a video/audio file you want to convert from your device. Under the arrow icon, you can also upload a file from a Dropbox account if you have one. After a certain time, your audio file will be uploaded.
Step 3. From now on, you can adjust some settings:
  • If you picked 'Convert', you can change the output format of your file, audio quality, and even type in the durations of the parts you want to convert.
  • For the 'Compress' option, you can move the slider for the file size that will affect the bitrate (or you can do it vice versa) and change the format as well.
Step 3
Step 4. Click 'Convert' or 'Compress', depending on your initial choice, and wait until the process is complete.
Step 4
Step 5. Hit the 'Download' button or upload directly to Dropbox. Easy, isn't it?
Step 5
Is Movavi Online Audio Converter Safe?
While most even free video converters, both desktop and online, are safe to use, it's always a concern when it comes to online tools. You don't want to risk your files by uploading them to an untrustworthy website.
Movavi, being a well-known software company, doesn't have any shady intentions. During and after using the tool, I haven’t faced any issues. No viruses, malware, spam, or other harmful elements were detected on my device.
You also won't have to worry about the files being stolen. Everything is only between you and the tool. The website uses a secure connection, and upon completion of the conversion process, your files are automatically deleted from their servers.
Pros and Cons of Using Movavi Online Audio Converter
Pros:
  • Intuitive user interface, making it easy for anyone to use
  • Can convert into many popular video/audio formats or compress the file size
  • No software installation required, secure and safe
  • The tool is accessible from any device
  • Completely free with no hidden fees or annoying ads. Extending reading: How to stop ads on Android phone?
Cons:
  • No batch conversion option
  • Limited settings for customization
  • Lacks advanced features compared to desktop software
  • As any online tool, it works quite slow for larger files or slower internet connection
Is Movavi Online Audio Converter Worth Trying?
Movavi Online Audio Converter is a fantastic option for quick and easy audio conversion. It's perfect for those who have minimal needs and don't want to deal with complicated software or pay for premium features.
The user-friendly interface, accessibility, and security make it a reliable option for anyone looking to convert their audio files hassle-free. Give it a try and see how it works for you!
Thanks for visiting Blackview blog.
About the author of the guest post - Ben Jacklin: Ben is a writer from the UK with qualifications in Media and Music Technology, he specializes in software reviews and tutorials. Ben has been blogging about media and tech subjects since he was a teenager from his base in the East of England.
Prev article: How BL9000 Pro Can Be Your Best Partner While Camping
Next article: Is MTK Dimensity 9300 processor good for gaming?
