  2. Tech News
  3. Does 4G Plus drain battery life faster?
2024-02-20 100 0
Welcome to Blackview (Well-known brand of rugged phones) blog. Hope the guide helps.
In the ever-connected world, staying energized becomes crucial for our mobile devices. While 4G+ offers blazing-fast data speeds, concerns about its impact on battery life persist. Does it truly drain your battery faster compared to regular 4G? Let's delve into the facts and explore effective practices to maximize your battery life on any network.
4G Plus and battery life
Understanding the Technology:
Before diving into comparisons, let's differentiate between 4G and 4G+. Both utilize LTE (Long-Term Evolution) technology, but 4G+ (also known as LTE-Advanced) incorporates carrier aggregation, combining multiple LTE bands for potentially faster download and upload speeds (theoretically up to 1 Gbps, compared to 100 Mbps for 4G).
The Battery Drain Factor:
The Truth: Yes, using 4G+ can potentially consume slightly more battery than standard 4G. This is primarily due to two factors:
  • Increased Power Demand: Achieving faster speeds requires the modem and radio on your device to work harder, leading to higher power consumption.
  • Network Switching: If your device frequently switches between 4G and 4G+ depending on available signal strength, the constant back-and-forth can contribute to additional battery drain.
However, the impact is often overstated. Studies and user experiences suggest the difference in battery life between 4G and 4G+ is relatively minor, often ranging from 5% to 10% depending on usage patterns.
Minimizing Battery Drain:
Regardless of the network you're on, adopting smart habits can significantly extend your battery life:
  • Adjust Network Preference: If battery life is a top priority, consider locking your connection to 4G instead of letting it automatically switch to 4G+. This might slightly impact download speeds but can conserve battery.
  • Monitor Data Usage: Streaming high-definition videos, playing online games, and using bandwidth-intensive apps inevitably drain your battery faster, regardless of the network. Be mindful of your data usage and adjust your habits accordingly.
  • Optimize Background Activity: Disable unnecessary background app refreshes and location services when not in use. These features can silently drain your battery in the background.
  • Reduce Screen Brightness: Lowering screen brightness is one of the most effective ways to conserve battery life. Utilize automatic brightness adjustment whenever possible.
  • Invest in a Power Bank: For extended periods away from a charger, carry a portable power bank to top up your device on the go.
Making an Informed Choice:
Ultimately, the decision of whether to use 4G or 4G+ depends on your individual needs and priorities. If you prioritize raw speed and are willing to accept a slight trade-off in battery life, 4G+ might be your choice. However, if maximizing battery life is paramount, sticking to 4G provides a good balance between speed and efficiency.
By understanding the nuances of 4G and 4G+ technology and adopting mindful usage habits, you can optimize your battery life and stay connected, regardless of the network you choose. Remember, the most important factor is finding the balance that suits your unique needs and usage patterns.
See also,
Prev article: Is 4G Plus worth upgrading to from 4G?
Next article: Why is USB-C standard better?
